Carrerasax
Does any one use these devices when travelling
How do you get wi-fi
Can it pick up local hotspot from a mobile?
I haven't yet got round to investigating a connection to power mine off 12V supply. I see no reason why it should not connect to a hotspot on your mobile.Does any one use these devices when travelling
I have a pair of them in my Motorhome (configured as Stereo speakers, which is possible if you have two identical Echos).Does any one use these devices when travelling
I personally am wary about using 'domestic' devices that are powered via a regulated DC voltage directly on a Motorhome/Camper "12V Supply" that could actually be anything from 11V to 15V at any given time, so I have mine connected via a regulator that provides a set controlled voltage.I haven't yet got round to investigating a connection to power mine off 12V supply. I see no reason why it should not connect to a hotspot on your mobile.
If using an Echo Dot also used at home, my preference would be to use the same SSID and password, so that it is not necessary to reconfigure the connection. This is easily done on my Teltonika RUT955.
I have seen the USB adapters for the Echos and have tried 3 different ones over the years but never seemed to actually work reliablyI have one in the truck. It's the older one that is powered from a USB socket.
I have seen the USB adapters for the Echos and have tried 3 different ones over the years but never seemed to actually work reliably![]()
You may zeed all you want, its fact, one thing i see is folk putting banking details on s phones, DONT, b inlaw lost over £300 by a snipper.ZZZZZZZZZ
And repeat .. zzzzzzzzzzYou may zeed all you want, its fact, one thing i see is folk putting banking details on s phones, DONT, b inlaw lost over £300 by a snipper.
I use one of these to power mine and I have a router in the van but I'm sure you can just use you mobile's hospotDoes any one use these devices when travelling
Hi Neil, do you know what Generation Echo Dot you have? Mine is a Gen 3 and is 12 volt not USB (5 volt?)I have had an echo dot in the van a couple of years or more, just plugs into a usb port and connects to my van wifi but it will connect to my phone hotspot if I want it to![]()
Ours is Gen 3 ....Hi Neil, do you know what Generation Echo Dot you have? Mine is a Gen 3 and is 12 volt not USB (5 volt?)
Regards,
Del
Regards,
Del
Mine is generation 2, 5v off usbHi Neil, do you know what Generation Echo Dot you have? Mine is a Gen 3 and is 12 volt not USB (5 volt?)
Regards,
Del
Of course, you do know if a post doesn't interest you, you don't have to read of comment?And repeat .. zzzzzzzzzz
