OMG who to believe???
Can you mend my horn?
The perils of digital info and supposed extra accuracy.
If they had analogue dials they would all have shown the same reading.
2 dec places is too much anyway.The meters will not be that sensitive..it is all an illusion !
However I have a 1 dec place meter permanently wired so I can monitor imy LB easily.
Sometimes at night the voltage DISPLAY drops to say 12.6
It may be 12 .5 or 12.7 but who cares..When using the same meter I can see when the voltage goes up or down. Which is good enough
They have all got " CE " on them.
This usually means " check everything "👍
My horn still doesn't work though !!!
try this garage .... I am sure that will get your horn working ;)
If you want high accuracy you'll have to have them calibrated.. ( most probably cost more than the meters ) :unsure: :ROFLMAO:
