marchie
Kev, when the ECU blew in November 2021, almost half of the £855 total bill was labour charges for tracing the wiring systems manually to pinpoint the fault that was causing a backfeed from the Vehicle Battery to the Leisure Battery, because Burstner wouldn't provide any schematic diagrams 'because we have to protect the expertise and economic interests of our partners [Dealers]' who told me just to pull the fuse! So the autoelectrician had to trace the fault one circuit at a time [and I told hom not to spend [chargeable] time replacing covers, upholstery etc, so I could see an open Manual for each of the Water Heater, the Water System, the Fridge/Freezer etc etc at the location of each bit of kit!It seems a lot more complicated than my build was, I had 230V inlet which powered the fridge and the Ctek plus two sockets we never used except for the vacuum, 12v via a fuse board to the hob, oven, Truma E4000, fridge light/fans, Carver Cascade, a couple of battery voltage gauges USB sockets & LEDs, a MPPT controller, but no structured access point as such, I put things as close to where they were needed as possibe, the solar controller was electrically midway between the panel and the LBs, Ctek right next to the batteries, 230v inlet next to the fridge and the air blower.
Having said that I was and still am clueless so it had to be simple.
So a 'Keep It Simple Stupid' approach, with marked cables/switches et al is more logical, easier to trace and understand, and therefore cheaper to maintain and repair!
