Solentmancub
Good day all,
I have brought an Ace Airstream 630 PR. It has a Truma 6002 fitted. it took me a while to get the hang of the Trumatic C & EH controls that integrate with the NE 183 Nordelletronica control unit. The Truma won't work on Space heater. The LED lights up, I hear a click which I think is coming from the heater but then nothing.
If I switch to heating & hot water all is good. Both fans run. The igniters works and the gas lights no problem. All fuses are good. I have inspected all parts that I can see & remove both fans to ensure all is well. I believe I am right in thinking the space heater should work on battery & use Gas?
Can anyone point me in the right direction for a resolution? I don't think it is a motherboard or the Truma Controls. The Temp sender is working fine too. The only thing I can think of is it may all intergrate with the Sargeant Fuse box too? I can see both the leisure battery & van battery connect to this.
