paulhelenwilko
Not unless it is stop-start.I have read a lot recently about smart alternators - could a 2013 Ducato have one ?
Does the motorhome mains charger have a deep cycle ?
Almost no standard alternator will come close to fully charging a house battery
Best you might do is 85% and then only after several hours of driving
Because the engine battery is only charged to 85 %I don't know how you have come to that conclusion Tony as for instance in my self built installation where I have a van battery which is connected via a split charge relay to 2 leisure batteries and at the end of a 2 to 3 hour journey all 3 batteries are showing over 14v when tested.
A 12 v battery con not be charged to 14 volts .check after a cooling of period about 6 hours 12.7 is fully charged .I don't know how you have come to that conclusion Tony as for instance in my self built installation where I have a van battery which is connected via a split charge relay to 2 leisure batteries and at the end of a 2 to 3 hour journey all 3 batteries are showing over 14v when tested.
