Bright sun but bitterly cold wind blowing. Moved back to the Santa Margarida Wine Aire late last night after the local yoof of San Quinti de Mediona sandwich country (all inbred) climbed down from their family trees and began causing a nuisance. For balance, the Ferreteria Owner who worked hard to find stuff for us keep the broken fridge door shut during driving, nipped to the Pastaleria next door and bought us a packet of the local speciality biscuits as a 'Thank you' for our custom!
San Quinti is a beautiful walled town with lots of ancient nooks and crannies and mediaeval squares to explore. We will be back!
I assume you've got enough water then😀
Only 80%, Lee..
It hasn't rained since you rain dancers left.
They are forecasting some rain, Monday and Tuesday. Guestimates vary between 2 and 40 mm and that changes every 4 hours.
Cold 8 degrees to start, with sharp Easterlies.
18 degrees is the max we'll see today.
Allegedly.
Serendipity, Steve..
Just when you're having niggling problems, something or someone turns up and gives you a pleasant surprise and memories.
Biting wind continued throughout the day, but the sun has been shining brightly (Solar Panel went to Float Stage around 13:20). Clear skies so expecting a chilly evening ...
got up to full sun this am by 2;30 registering 33deg outside sensor beat my record yield easily gone from 1.68 kilowatts to 1.91 kw had fridge running on solar for 9 hrs lithium battery back to 100% , going to be so sad to leave this little slice of paradise 4B63EF86-ABAF-4F84-A945-D69FE44553C2.jpegCF0EFDC5-B3CC-490B-991B-328B07DB4311.jpeg
I woke yhis morning to 2 degrees here in Blaye near Bordeaux, beautiful sunshine but cold.
Looking at the forecast it went down to -2 overnight and there's a griund frost this morning, who'd have thought it in France.
After a slightly lighter overnight frost, it's dawned into a beautiful bright dry day with a maximum of 9°. I'll become more overcast by late afternoon. 🙂
Nippy morning, brisk Easterly.
8 degrees at dawn, 17 max, allegedly.
Makes a change to eat lunch indoors.
Maybe time to change the smug filters.
We've had a great time at Blaye wine festival, although cold the weather has been a lot better than forecast and of course we have had the alcohol to warm us up.
another bad forecast another beautiful day started slowly heading north now at Elvas at starfort graco stunning tomorrow’s forecast dull & only 14 deg the red sky tonight promising a little more , damn photos on i pad never show the lovely salmon coloured sky3EAE9C63-FFC9-4E7F-8234-FE131BAF8F5A.jpeg
It's going to rain all day with a high of 9°. 🌧️ That's good news because the plants need it. (y)
Reactions: 2cv
Drizzle.
1.9 mm per hour....
ENE winds ,10 mph.
Real feel 6 degrees outside.
We're staying inside.
Smugfilter redundant.
Another chilly night but beautiful morning here at Monbazlliac a promise of 13 degrees and sunshine today.
We're moving on along the Dordogne hopefully the weather will stay with us.
