Got my water working again after replacing the Water Pump that refused to prime and now found a new problem
I will start by saying that I did drain down the water and leave the taps open so although the temperature did fall below zero on quite a few occasions, it shouldn't have had an effect on the pipes or taps.
So the problem ... When I turn on the kitchen tap, I am getting a leak from the body of the tap but I cannot see anything to remove to service (maybe just a washer needed?) or even to remove the entire tap. Below are photos of the tap from the top and underneath the worktop.
Motorhome is a 2007 Model Autotrail.
The Tap ...
This closeup shows where the water is leaking out ...
And an undercounter shot - how is the tap secured in place? is that a very large circlip maybe? (sorry for focus. best I could manage)
The Tap ...
