Remaking a garden bench.
We bought these bench ends about 15 years ago at a steam fair auction and it's time to build it up again.
I think it needs to be 4-5 feet long, but not sure what to use for the slats, it looks like it has had slaters lathe previously not the best I think so suggestions from anyone has a s similar bench as to word and sizes as these don't look correct, I'll need a length of rod to stabilise the bottom too but that the easy part.
Did mine a few months ago the ends cost £ 10. The pair . We used cedar woof. From old thick fencing. Recycled.
But then used the timber patio wood for a table top.
I see there are another pair for the same price. And funny enough there the same as we have and again from the very same seller.
But one is enough for us…
First thing is get the ends shot blasted and a good epoxy 2 pack primer on them, we used to get a lot of them in, turned out nice when finished in poly 2 pack, should be cheep to do.
What dimensions are the slats?
There are a total of 12 on mine .
The top back is. 35 mm wide
The last two on the seat bottom are 2 x35 mm
All the other 9. are 60 mm wide The total length of them are. 1.200 mm
And there all 25 mm thick.
So that’s 9 x 25mm x35 mm x1.200 mm
3 x. 25 mm. X 35 mm. X1.200 mm
24 x 6 mm galvanised gutter bolts and nuts.
1 x 10 stud bar 1.300mm.
4 x 10 mm. Nuts and 4 10 mm. Washers.
Patio decking was my second choice. But used some redundant cedar fencing.
Great, thanks not sure we're going quite that long 4-5 feet I think.
The brace I think I'm going 8mm all-thread with a dome nut at each end for tidiness and a nyloc nut with washers etc on the inside to hold it all tight.
Mines 47 inches. Long .
Just another thing we're quite hefty peeps (Yorkshire folk don't leave food on the plate) so I was wondering how much your slats bend with two peeps on it?
T
They don’t they have a strips of something underneath . 3 in number I think they’re something to do with roof straps galvanised straps bought on a roll and has many uses…. I am sure it was called a roll of roof plate strapping .
Just spent the afternoon dismantling a couple of benches as the wood had rotted, meaning to refurb them. However accidentally ran over the wrought iron ends with the tractor (I’d carelessly left them lying in a heap in the long grass) and two got broken. Unfortunately I’m left with a mismatching pair! Might still make up an odd looking bench.
When
put it together then just push one end into a bush then nobody will know.
If you don’t have a hedge or something you can always say it’s a custom made bench.
There were two of them to make a pair but you only wanted the one .👌
