wing mirrors
WOODY 2026
I hope someone can help me. I have a 2021 Elddis 194 van. Passenger wing mirror was damaged and while it still works including indicator it will need replacing prior to bi-annual check. Van is based on Peugeot Boxer but Peugeot replacements are extremely expensive and I am sure a generic would do. PLEASE...can anyone tell me where this could be sourced? Thank you
Yup ebay has loads of Chinese copies, with or without the other bits, so a simple case up to the full monty
Go to eBay and ROBUST veh parts make sure you get the correct length of arm around £80
kba on line also do them
Thank you for your advice. I have certainly found one on (eBay) which has the right arm length and everything looks the same as mine. What I don't understand why these are readily available and at such a good price and are they a good buy? Peter
Made in China, not from the Fiat parts department.
I bought some white covers for mine off ebay, the cheapest I could find to cover a crack in the originals, they're still intact if a bit bashed about.
Attention, modern Boxer/Jumper vans have the ambient temperature sensor on mounted on the under side of the passenger (left hand steering) which is very important for the particle filter regeneration. Without this temperature reading it stops the regeneration process leading to future problems.
