Makers name for this type of hab door lock?
runnach
Advice please. Can anyone tell me the make of this lock? It is broken, it does lock door from the inside, but not from outside using key ( I only have one door ) I’ve tried a google, nothing jumping out at me. If I can have makers name of handle, I’ll try and source one locally around Grasse.
TIA.
It is the outer part required Jim, this holds the lock tumbler, but buy the whole lot if required?
Thanks to Jim and Tom for their input re: lock. Much googling required by me for a local lock replacement 👍
TIA.
View attachment 76275View attachment 76276
Bit late to the thread, but is it the actual lock itself you are trying to track down? or the surround itself?
If it is the lock, then you have a 'Zadi' lock, also called 'Vecam' and possibly has other names as well. It is like a standard lock used in just about every motorhome in UK and Europe it seems.
The same lock is used in cassette toilet door, water locks and external lockers.
Not going to say this is the cheapest option, but may be the most convenient from Amazon France ... https://www.amazon.fr/-/en/Cylinder-Replacement-Caravan-Extractor-Original/dp/B0C9JS18Q5/ref=sr_1_5
Gets you a new replacement lock and two keys. Plus the Red Key which is used to remove and refit the locks (when unlocked).
There are a host of Zadi lock and surround combos here on Amazon Germany - https://www.amazon.de/s?k=zadi+lock&crid=3DV2NTLY3Q76T&sprefix=zadi+lock,aps,107&ref=nb_sb_noss_2 , one of which may suit?
I buy from Amazon Germany quite a bit as it is often cheaper than Amazon UK even with expedited shipping. Usually takes around 3 days to arrive and weirdly the last package I got last Thursday from Amazon Germany came from France!
