Victron high voltage reading
Robina
Looking for some expert advice please (for Neil) - hoping Phil might have some insight.
2012 Bailey Approach 620 SE. Battery Master fitted.
Victron Gear:
2 x Ecotree Lithium 110ah batteries
1 x Victron 1P22 mains charger
1 x Victron MPPT solar charger
1 x Victron shunt
1 x Victron B2B charger
1 x 120 watt solar panel
We mostly use hook-up at a site or move on from free sites after a couple of days at most. Very low electricity users, 2-4 hours tv per night, all lights in van are LED. The lowest state of charge after a night with no hook up has been 92%. Reaches 100% after about 1 hour of driving.
Using the Victron Connect app, I checked the shunt history and noticed that the maximum voltage recorded was 14.67 volts. Was advised that this is a little high and to reduce it 14.3. Went into settings and found that the maximum voltage was correctly set at 14.2volts. I was also advised to ensure that the Mains charger and the solar charger were both set to the Lithium battery settings which they were.
In order to set a new baseline I deleted the shunt history settings. These now show the maximum voltage is back around 14.2v. However, the solar charger history settings show that the maximum voltage is frequently at about 15v and up to 15.33v. These readings are not recorded on the shunt history.
Concerned about these high (15v+) voltages, I have done the following:
1. Ensured that the absorption duration setting is set at ‘Fixed’
2. Reduced the absorption time is reduced from 2 hours 0 minutes to 1 minute.
Thus when the solar has completed Bulk charging, it moves to Absorption for only 1 minute before Float stage.
Do you have any idea what the cause of the high voltage readings are on the solar history and is there anything else I should do, check etc ? We are back in the UK in mid-March. Currently in sunny Spain.
Thanks for any help.
Bottom line (tell Neil this)
The batteries are not seeing 15 V
The shunt confirms everything is safe
This is a known Victron MPPT logging quirk in high sun + low load conditions
No damage is occurring
No urgent changes required
If anything:
Ignore MPPT “max voltage” history
Trust the shunt
Hi Phil, Neil here. Thanks ever so much for the swift advice. One quick question; in the light of your advice, should I reverse the changes I made to the absorption time from 2 hours to 1 minute?
Thanks again.
For those that are interested...
Absorption exists mainly for lead-acid batteries to:
  • Push the last 10–20% of charge in
  • Overcome rising internal resistance
  • Complete chemical reactions inside the plates
LiFePO₄ batteries:
  • Accept charge at a near-constant rate until almost full
  • Have very low internal resistance
  • Reach ~98–99% SOC before absorption even matters
  • Do not need to be “held” at high voltage
So absorption for lithium is not about charging the battery
It’s mostly about:
  • Giving the BMS time to balance cells
  • Letting chargers transition cleanly to float
It’s mostly about:
Phil's spot on with this and I'll add that the variables in BMSs used and their speed and ability to balance the cells means some BMSs need a considerable amount of time sitting at around 14V or more in order to achieve a full top balanced so personally I'd leave the settings at 2 hours absorption which I think is the the Victron LFP default?
You're a very light user and you'll probably never realise that your battery has become unbalanced until you need to use it's full capacity whereupon it could fall well short so it pays to keep it maintained correctly.
