I am selling one of my Poweroad Infinity Subzero Batteries.
Info on Battery:
This is a 100Ah Battery (internally actually approx 108Ah) and instead of just having a simple BMS that stops any charging at below approx 5C, the Subzero battery has an intelligent BMS that controls more precisely how the charging operates (see the attached flowchart), allowing the battery to charge at lower rates below 0C, and at higher current, use the built-in heater to warm the battery and allowing the charge current into the battery in stages.
In colder weather, such as we have now and will have until Springtime, a Lithium Battery with a standard BMS and no heating function may never charge if in an external locker (or even inside in an unheated van).
The battery state can be interrogated via the Poweroad App on your Phone or Tablet to check the State of Charge and cells. The following are some screenshots from earlier this morning:
Initial App Screen:
Main Screen showing State of Charge, Battery Voltage and general Status
Detail Screen showing Voltage, Current (and if charge or discharge); Individual Cell Voltages; Temp; and Lifetime Cycle Count
This battery has only had 15 charge cycles in total, and as can be seen the cells are nicely in balance, with just 0.004V (4mV) variance between highest and lowest.
It is designed to be a drop-in Lithium Battery, and with the Bluetooth Accessible BMS data it genuinely is as long as you have a Lithium Compatible Charger (or use one of my Wildebus Lithium Controllers if using on a Hybrid setup)
I have been using this as (and is still right now) part of the Lithium/Lead Hybrid Battery system in my Motorhome (see here for more info - https://www.wildebus.com/hybrid-battery-bank-introduction/) but I want to now test out some different batteries, hence why this one is up for sale
Looking for £480 for this hardly used (just 15 charge cycles remember) 100Ah LiFePO4 Battery with integral heater and Bluetooth BMS with 150A Current Capability.
Most Lithiums have no heating ability, no accessible BMS and a 100A Current limit and cost more than this one!
Info on Battery:
Battery Serial Number: PRHEATLA300321C180029 (Bluetooth number in screenshot is the Battery BMS Number) |
Integral Heater within Battery Box. |
BMS: 150A BMS with Bluetooth Interface |
Cell Type: Pouch cells |
Weight: 12KG |
External Data Interface: RS485 & CAN |
Initial App Screen:
