On the couple of m/waves I have been arsed to take any notice of, if you can lower the cooking power it's always been done by periods of on/off that vary in time according to the level you set.
I just tried the "manual" Microwave I have in the house - dial for power and dial for time, no display of any type - and yup, it also does the full/no power cycling just like the "fancy" one and just like every Induction Hob I have used.
Shame really as it could be a good way to have a single unit that you can run on full power when on EHU and lower constant power on
inverter (which would be a little kinder on the
battery)
While the microwave was out I thought I'd take a photo of the label on the back ...
So as can be seen this 700W Microwave (650W-700W depending on your voltage I guess) actually draws 1100-1150W of AC Power, so you need an
inverter larger than that to run it
In terms of
battery power, I took this photo of the Cerbo screen so you can see the power and current pulled (as it happens the DC load matches near exactly the
Solar input, so the power and current bottom left relate directly to driving the
inverter to power the Microwave shown on the top right).
so on a
Multiplus 12/1600 (1300W)
Inverter, to drive a 700W you need to provide around 1100W (1086W shown) and this is pulling 1333W from the
battery.
I have a pretty healthy 12.6V at this draw so the current is *only* 106A. If you have all Lead Acid then the voltage would sag more and the current would be greater. If you had a Lithium
Battery Bank that could deliver a current of 100A (many Lithiums cannot and you might need 2 or even more to do so) then the voltage would stay higher and the current less (an advantage of a good sized Lithium Bank over Lead Acid).
