David Tester
My fridge in my 1997 Hymer is causing the circuit 1 10A fuse to blow, I have disconnected the blue (12v positive) wire from the terminal on the top of the fridge, this terminal is an integral part of the casing of the fridge, it no longer blows the fuse when disconnected. Why would the blue 12 volt positive wire be wired to the fridge casing, I would have thought this terminal should be a brown negative wire.
Actually the hymer is my daughters so dad gets the good jobs to do on it.
