3 way fridge
  • Thread starter Deleted member 3181
  • Start date
Deleted member 3181
Hi all
Electrolux rm6 series
Just thought I would share a problem I had with my 3 way fridge.
The gas would fire up but would not stay on.
After changing a couple of things on it it would still not work, I found that there is a thermo switch on the gas valve, if you put a wire between the two terminals on the switch and it stay on after releasing the gas knob then the problem lies in the 6 way switch that you use to turn it from 12 volt to 240 volt to gas.
£50 brand new
