ABS light
Patrick1
Fiat X250 2014 2.3td. the ABS light came on and the error code referred to the left rear wheel sensor. I figured to get it fixed when I got back from Europe. The light stayed on for the next 2.5k km and then just went off. Am I just lucky or is the whole ABS system broken?
I cut tracking and rewired round all that cr-p on my car to pass mot which it did.
How did we manage years back without this cr-p.
Prob dirty sensor or ring ,self cleared should be ok if it is not a permanent fault it will clear itself,if it's a permanent fault it will not clear
Time will tell🤞
I have a Hymer B598PL 2016 2.3L engine. We headed for France late May of 2024. Before we had travelled 50 miles enroute for ferry, I got the ABS light and an alarm from the tyre pressure monitor that I had fitted some years ago. The tyre pressure was fine but the temperature on the back right wheel was at about 70c if memory is correct. Burnt my fingers when I touched the rim. The other 3 wheels were all fine. Van serviced at start of year and a few weekend trips done. I always park at home with handbrake off, although on occasion the pads stick momentarily when moving after a park up for a while. I thought it would clear itself so we proceeded to the boat. The ABS light did not show during the rest of the 5 week trip.
The wheel was constantly hot for the next 5 weeks. We amended our plans and drove no more than an hour when we moved, closely watching the wheel temperature on the tpms, stayed longer on Aires than usual and remained in Brittany, to be close to the ferry. During the first fortnight I called at 3 Fiat professional garages, a small independent and a Motorhome dealer. None were prepared to even ‘look’ at the wheel. 3 weeks was quoted more than once before an appointment would be available. All I wanted to do was remove the wheel, look at the brakes and calliper and see if they could be freed. Ce ne pas possible monseiur.
On return home, my garage diagnosed a faulty ABS control unit. A very expensive replacement (circa £1000) as we were due to depart for France again about 5 weeks later and to obtain a cheaper reconditioned unit the faulty one would need to be sent off with no certainty of return date. Needless to say the wheel needed new pads, the only upside being that the disc was fine. After removing the old pads, which were almost at the rivets, a sharp tap on the ground caused what remained of the pad to fall off and break up.
Sorry to detail this tail of woe, but do check the wheel temperature during or after each leg of your trip. The subsequent September trip had no brake issues, just an alternator that run at excess voltage and fried the one year old Lead carbon habitation battery. Fortunately the 8 year old starter battery which was replaced in the January service as a precaution survived without issue. So new alternator and a Numax 110 amp sealed lead acid made 2024 an expensive year!
Hope you get an easy and cheap fix and enjoy the rest of your trip.
Davy
Thanks everyone. I did have the right rear wheel sensor replaced earlier. It was melted into the casing. My main worry was that the ABS control unit would have a hissy with the light being on so long. I have decided to let it be since the light is off and as mentioned above why do we need all this extra stuff anyway. The answer is if course that the Young's haven't learned how to drive without them.
Its more junk to go wrong so back to the dealer with wads of money or the scrap yard after its a bit old and not worth wasting money on.
