Wondering if anyone knows the answer to this question .....
Take the typical Induction Hob ... If you run at full power , it uses the full power. But if you set it to a lower setting, it does not run at the lower power, it runs at the full power for a time, then turns off, then full power, etc. cycling between the two to average the power setting chosen and you see that in a pan of water with the water bubbling, stopping, bubbling, etc.
The typical Microwave works in the same way, power cycling between full and on to average the power set.
This is important to know as if you are using an Inverter, you don't want the power of the Hob or Microwave to exceed the Inverter rating.
Now the question ... Does an Air Fryer do this pulsing power cycling or is it a more basic device where if you set it at 50% of the max power, it draws 50% of the power all the time (rather than 100% for half the time and 0% for the other half)?
I *think* it is a fairly dumb device when it comes to the power as they are usually an electric element (like a kettle or old-fashioned electric cooker coil) that is powered and a fan above it that pushes the heat down to the food basket, but I would be interested if anyone actually knows (I am just guessing).
reason for question is got to get myself a new one (see Air Fryer recall post) and thinking could maybe get a more powerful bigger one and restrict using it to a lower power when off-grid but could 'unleash' it if hooked up?
