Alde heating
Carrotts
Hi all first time dealing with alde hot water/ heating. Read manual 5 /6 times. Finally got hot water gas to heat. No joy with hab heating says switch on expansion tank heater. Does not say where how. See two photos of part of set up. Does not say what they are. Any ideas clues. Hints. What happened to the simple on off switches
Switch system off .
Wait few seconds .turn on .
Turn back on .Press menu
You should see this screen.
Select gas.
Then select which function hot water .And then top one heating you may have press the plus a lot to get temp seting hire that room state..
Wait screen should return to a temp pic with a house and circle in top right corner if no circle temp not set higher than room temp repeat. Hope helps I am not the best to explain .You will no if on as header tank fluid move a bit.
Hi. Tried that. Could it be that I can’t test the heating. As the temp in van is to high says 32. And I can’t set temp over 30. Doesn’t feel 32 in van. Also my first two pics show top right. Circ pump with a pointing hand and pic two top right circuit pump Not sure what. This pic shows temp And elec symbol. But electric says off gas on !!!!!!!!!!!!! Thanks brian
I would think your right heating will not work till below room well on ours that's how it is .
I would say the internal temp readings are not accurate at all.
Ours say 26°today and it's only 18°today .
Thank you very much for all your help ,one last question though ,do you have any drawers on your motorhome as none on ours,not even a cutlery drawer
As I understand it from other forum post on fb if you turn hot water to max as you have, then heating will not work until hot water demand is met, try turning the hot water down to half way.
Bailey Motorhome Owners Group on facebook is very good for these sort of questions.
We got great help from Bailey motorhome group .But we left .
The negative from the Bailey haters was not good .
