Erneboy;n14601 said:
Been full timing for around eight years now. My best tip is to have as big a van as possible, it makes the experience enjoyable as opposed to just tolerable.
make yourself an inline water softener which you can use when filling the tank
[h=1]Softening hard water[/h]
The damaging effect that hard water can have means that it may be beneficial to soften the water. Methods for softening hard water involve the removal of calcium
ions and magnesium ions from the water.
There are two methods for softening hard water:
- adding sodium carbonate to the water
- using ion exchange columns
[h=2]Adding sodium carbonate[/h]
Sodium carbonate, Na[SUB]2[/SUB]CO[SUB]3[/SUB], is also known as
washing soda. It can remove temporary and permanent hardness from water. Sodium carbonate is soluble but calcium carbonate and magnesium carbonate are insoluble.
The carbonate ions from sodium carbonate react with the calcium and magnesium ions in the water to produce
insoluble precipitates. For example:
calcium ions + sodium carbonate → calcium carbonate + sodium ions
Ca[SUP]2+[/SUP](aq) + Na[SUB]2[/SUB]CO[SUB]3[/SUB](aq) → CaCO[SUB]3[/SUB](s) + 2Na+(aq)
The water is softened because it no longer contains dissolved calcium ions and magnesium ions. It will form lather more easily with soap.
However, the calcium carbonate and magnesium carbonate precipitates to form
limescale. As well as being unsightly on your taps, it can also clog up pipes in heating systems (causing them to break down). This makes treatment with sodium carbonate suitable for softening water
only in certain circumstances - such as softening water for hand washing clothes.
Where it says 'only in certain circumstances' (last line) do you have any experience of what they are saying?
