Exwindsurfer
Been thinking about this for a while .I have a plate glued to the roof of my van just above the drivers seat with a 10mm bolt sticking up to screw my aerial mast to but the problem is I needed a ladder to put the aerial up.As my solar panels are now are remote controlled I don’t need the ladder so I’ve made this up. It’s two suction pads drilled and fixed 6mm bolt through them to fix the mast to them. It works great and very easy to assemble in minutes just waiting for the aerial to come.PS you can just see the inlet box just below the mast to plug into.
