BanjoMandolinGuitar
StreetSleeper
As I had a bit of time on my hands I decided to relax and try something different. For a long time now I have been toying with sticking a guitar neck to a banjo/ukulele pot. Fairly straight forward job, find two broken instruments and stick them together. Here's the start of the project; I think I've got the size right.
48176
As you can see, above, my violin conversion sitting next to my new creation. Surprisingly, not a lot of difference in size.
48177
The bridge is a little tight to the edge, not sure if this will affect the sound too much; we'll just have to wait and see.
48178
Had to notch the bowl to get the action down on the neck.
48179
Still needs a little more work to get a perfect fit but I think we're getting there.
48180
I'm quite pleased with this part of the job. All I need is to glue another piece of wood in front of it so I can fix the neck more securely to the body.
Work has now stopped due to parts being ordered from China so, hopefully, the conclusion should be in about three months time; if the Chinese post is to be relied on.
Rae
StreetSleeper
Love the Violin body, looks much nicer than my Washburn Travel Guitar
Hello Graham,
Au contraire, it was yours I wanted but, at the time, I didn't have the money so I had to settle for making my version of a travel guitar.
Rae
Deleted member 24
Hello Graham,
Rae
Well Rae, you certainly have done a superb job. Hope it sound as good as it looks (y)
Val54
Out of interest is the bridge so close to the endpin to get scale length or were you concerned about the violin table taking the strain?
StreetSleeper
Hello Dave,
A little explaining on the construction of the violin guitar. First of all the violin was taken apart, a piece of oak three inches by half an inch runs from one end to the other, at the back end it is made up to support the strings from the inside, the same as the neck has been spaced out using oak to give the right height. Inspired by Les Paul's design of the log. Two thinner pieces of wood form the upright inside the violin body and then expanding foam was squirted in to give the body some sort of rigidity. My original use was to put a pick up inside it but I quite like it as a practice guitar. On both of the instruments the bridge is in the correct place, it just requires a bit of doctoring to get the strings to fit.
Rae
StreetSleeper
Hello Graham,
This is my new travel guitar, picked it up a few weeks ago, quite reasonably priced as it had been damaged but that repair has now been done and all I need is to respray the damaged area but a nice instrument to play.
48187
Rae
Val54
Ah thank you for the explanation Rae, I was certainly wondering how you had managed to keep the violin body in one piece without major surgery!!
PS. Nice work on the resonator
Dave
StreetSleeper
Hello Dave,
I knew you should never strum a violin and when I was taking it apart I realised it would drastically need underpinning and, fortunately, it seems to have worked as I normally carry it around in the van and it's survived so far.
Rae
Deleted member 24
Hello Graham,
Rae
Another looking good, however I prefer all acoustic for travel as no need to carry an amp or other gear
Nice though, maybe set up as a Luthier
Val54
...I knew you should never strum a violin...
I do occasionally, but only very gently ??
Dave
StreetSleeper
Hello Graham,
Well this is the set up.
48189
The amp was a present from the children.......or should I say adults and I thought I'd have a bash at eliminating the lead and having this box of tricks that seemingly has five functions. Never tried it out yet so don't have an opinion.
48190
To be honest with you I prefer acoustics, I thought I'd try this new one out as I was quite intrigued with the machine heads. They do an acoustic version of this, which is basically the same but with ear plugs and no pick up.
Rae
Val54
Have you never tried Air On A G String? ...... I wasn't allowed to Rae ??, for the odd gigs that we still do the tempo is slightly faster........... I can't upload a sample as Phil doesn't allow MP3 file extensions but if you are interested you can find us at www.flaxmere.co.uk
Dave
StreetSleeper
Have you never tried Air On A G String?........ I wasn't allowed to Rae ??
Hello Dave,
Baching up the wrong tree?
I shall have a look at the link you posted.
Rae
