TrevandJenny
Our MH is fitted with the Sargent 328 electronics system, As I understand it when on hook up the 240v supplies the ring main as well as the 12v system. I understand a transformer drops the current for use in the 12v circuit as well as battery charging, depending the draw on the 12v system depends on the amps available for charging.
As the 240v input is not compromised by, for example the fridge on mains, can I use a quality battery charger maintainer plugged into mains circuit in MH and connected to leisure batteries.
My thinking for this is the transformed voltage from the charger will have more amps to the battery than the onboard 328 system.
