Blocked drain tube ........... how do I clear it?
Dolomite Pete
I have an Autocruise Rythem and the tube that the bathroom sink drains through is partially blocked. The sink is one that hinges down, and the plug hole just empties into a black plastic chute with the tube running into the waist tank. Is it ok to use a chemical drain cleaner? I can't get a rod or wire into it. Has anyone else had this problem? I don't want to use bleach or anything that strong. Any ideas?
Many thanks
I wouldn't use wire or similar to poke down, it could get stuck or rupture the pipework.
If the bicarbonate of soda and vinegar doesn't work you could use Mr muscle drain cleaner, I've used it without any detrimental effects.
Not sure I'd use boiling water as I know someone who deformed their basin doing that - sorry to contradict someone's advice.
The cause will more than likely be hair mixed with the foul gungy muck that you always tend to get down these convoluted pipes.
Either of the above methods should effect results but if all else fails as it has in the past for me, I have used a length of flexible multi-core wiring cable that I have given a very rounded end to so that it won't damage the low quality pipes that I am afraid are always fitted to mega expensive professionally built vans.
And once you’ve cleared it, put hair traps on all your plug holes .... I could stuff a cushion from my hair loss after every shower!
We’ve a plunger on board ... worked for us, but I know it is not generally recommended.
If your going to use curtain wire. I would go with the eye end rather than a hook. If the hook catches on a pipe join it will be a pig of a job pulling it free.
Bicarbonate or cola would be my choice.
I use a 200mm piece of 25mm broom handle inside a 150mm piece of 25mm bore hose as a miniature plunger.Just fits over the drain outlet.
I don't know if all are the same but I unblocked one of those types of sink for a couple parked beside us and in their case it was just hair in a gauze at the sink joint seen with sink raised
