Carrerasax
Try a hot air gun and warm it up it should stretch it backIs this normal after 4 years.
Looks like it’s shrinking!
What’s it likely to cost to have replaced and how tough a job to fit? In warmer weather probably when it’s not so stiff!!!
Silicone shouldn't be used for sealing - or probably anywhere else on a motorhome. The correct stuff to use is a non setting sealant purpose made for motorhomes and caravans - for instance SeamsealHave you lost a bit of plastic? Looks like there is a trim fitted to left of upright but not to right. if not, the usual silicones in tube/gun should do the job for little cost.
