I'll have to measure our bottle but the 5 kg is really slim. We saw them at the show. It's the first link I gave you above.Hello, thanks vey much for for the feedback is the gas bank refillable bottle that you use 310mm diameter? If so that is too large to fit in our gas locker. I did notice however that gas bank do a slim 5kg refillable bottle Which I will have a look at.
You could try Camping Gaz, they are more expensive in the UK but I gravity fill them from a larger calor bottle. Not generally considered safe but with suitable precautions no more dangerous than filling your lawn mower with petrol.Thanks for the feedback, I am aware that the standard Calor bottles can be used but I was hoping there might be another light weight option to avoid the extra weight of the steel bottles.
I decant from normal calor bottle!!Hello all,
does anyone have an alternative to the discontinued Calorlite 6kg propane gas bottle issue? I purchased a flogas gaslite 5kg bottle as a replacement but the diameter of the gaslite bottle is too big to fit in the gas locker.
