I have this 30L Single coil Horizontal Calorifier I am about to fit in my Crafter.
SureCal boilers are made of the finest quality materials, which guaranteeing the ultimate performance and reliability. In addition the drop coil technology and finned surface heat exchanger used in the boiler provides unrivaled heat recovery. The units also come in twin coil version for use with...
www.surejust.co.uk
I will be installing it in series with the heater matrix by removing or cutting the return flow hose from the heater matrix and connecting the return from the heater matrix side to the Calorifiers coil (the Surecal manual indicates that to be the RH port which may or may not actually matter) I will then take the LH port back to the engine block side of the original heater matrix hose.
This is to ensure on cold days, as the engine warms up, that the heater matrix still gets the available heat first, otherwise defrosting the screen could take forever and it still might!
You need to remember without fitting bypass valves that this setup will work in reverse to a degree as well, during a cold start any residual heat in the calorifier will be dissipated into the cold engine block and might assist in warming it up slightly.
End result will be a rapidly cooling tank though hence not a good idea to go for a five minute drive down the road and then stop for a shower!
Depending on how well this works as a source of DHW especially when off grid for a few days I may or may not also fit a block heater in the same water circuit seeing as I have a couple sitting spare on the shelf.
My Calorifier currently has a 1.2KW 230v immersion as well which might get replaced with a 300W 12V version which could make use of spare
Solar and would still work on mains hook up via the mains
battery charger.
I also have a spare rear passenger area heater matrix from a black cab similar to the one linked below complete with two speed fan and I may install that in the garage area at the back of the van as well eventually as these are great for eliminating condensation.
The Demon Tweeks Lightweight Heater has been developed for bespoke, kit cars or competition cars.This heater provides optimum output yet ensures compact dimensions ensuring its ideal suitability if weight reduction is required or the application simply does not have a heater and one is required...
www.demon-tweeks.com
Getting DHW like this is a bit of a faff, In my Sprinter I have a far simpler and more effective system one of those dirt cheap instantaneous water heaters it's worked flawlessly for the last three years and for the £70 it cost has been brilliant, unfortunately I don't have room to fit a flue for one in my Crafter.
