bobuk
Hi All
I hope someone can help me
I have a 1999 Peugeot Autosleeper Harmony which is fitted with a Carver P4 Gas Heater
I’ve had the van about 8 months and It’s been working fine but we haven’t used it much over the last few months
Now when I try to start it the green LED comes on on the control panel as it should and the heater goes through its purge and start up as it should and if I look at the heater unit its self there is a yellow LED that comes on when it fires up
This stays on and the unit produces a bit of heat for about 30 seconds the yellow LED then flickers a few times and goes out and the boiler shuts down it goes though this cycle twice then the whole unit shuts down and I get a steady red LED in place of the green one on the control panel
I’ve had a good look online but can’t find a decent fault finding flow chart for this system
If anyone can be of any help it would be greatly appreciated as were off to the New Years Bash in Hereford and I suspect it’s going to be cold
It also has a separate water heater but that’s working fine
Thanks Bob
Thanks Bob
