Vanterrier
Readying my van for this years first outing I noticed some odd readings on the CBE panel...
Everything in the van switched off...(everything appears to work ok when they are switched on)
Switch panel on and test battery, voltage ok but a 0.5 amp load shows ???
Now turn on water main switch and load increases to 1.0 amp.
Now turn on lights main switch and load changes to 1.5amp.
I cannot figure out why the load should increase just by turning the main switches on with nothing actually switched on?
Could I have a parasitic draw? But why would the load change depending on which main switch is on?
Does the panel itself need some kind of reset or calibration?
I have not yet tested the battery with a meter.
Any ideas, suggestions?
K
K
