Nobath nomads
Thanks rogWell done Steve, looks like a proper job!
Sounds the same as my Pilote was from the factory.It was in the centre of the van with a long handle coming out st the side, on the picture it was on the left where the shower trap is now
Had the motorhome almost 2 years and no issues to date thankfully.Like mine, yours looks quite low. Have you had any problems with either reversing on low kerbs etc, or with emptying
I got under the can again today, armed with 2x 45degree bends. The problems I encountered were things like handbrake cables and other fairly low slung things. The result is I have trimmed as far as I can the brackets and measured the distance I have 6" clearance.Looks a good job, however I have seen a few knocked off go kerbs and tree stumps. If I were you, I would alter it to drop out between the front and rear wheel, ideally just to the front of the rear wheel
Better now while you are at home with the facilities, than when you are away
