The closest to genuinely affordable plug and play Lithiums I have seen would be the Poweroad Infinity SubZeros.
Reasons:
You need a proper
battery monitor with lithiums as using voltage levels to determine charge level is doable with lead, but just doesn't cut it with Lithium. The Poweroad Infinity range have a built in monitor accessible via Bluetooth which while not taking the place of a proper
battery monitor that ALL systems would benefit from, will do the job, and better than a voltmeter with Lead Acid would do.
If you try and charge a lithium
battery when it is cold (below around zero), depending on the BMS (
Battery Management System) fitted to the
battery, it will either be damaged as it allows it to charge regardless, or you cannot recharge the
battery until it warms up. The Infinity Subzero allows charging down to -20C (by using internal heating pads), so you don't have to worry about that aspect.
Systems like Sargents are probably undersized in terms of charging capabilities. One of the major benefits of Lithium Batteries is their ability to recharge very fast. The typical motorhome charging system (both on Mains or Alternator Split Charge) is too weak to make the best of them, so I would say you would really need to get a new Mains Charger and/or Split Charge system to get the best value from them, but probably ok to use what is fitted as an interim.
