Tidzaken
Noticed a wet patch on the ground under the van and traced it to a water drip from the floor which has started to go rotten in the corner. It appears to be coming from an area just behind the cab where the main body of the van is attached.
There is a cavity which has been utilised to run cables etc and the inside is wet with condensation. Think I can tackle the floor repair OK, but wondered if anyone had ideas about eliminating the condensation. I had thought to fill the cavity with loose fill insulation.
