After exactly one year old our water pump has gone.
Does anyone know the make/model?
Supplier of Van appears to have problems obtaining one so trying to source one ourselves.
I don't know your van but if it uses a submersible pump I would recommend the Reich 19ltr Twin Submersible pump.
When the original pump failed and the similar replacement had poor pressure after a short time i fitted a Reich 19ltr Twin Submersible pump. It's been in use for many years with good pressure.
My hymer uses the Reich 19 litre twin pump which gives a pressure similar to that of my house. However it is a large oval (when looked at from above) shape. My van has a marine screw inspection hatch which is about 6 inches in diameter so access is straightforward. Your access may dictate what you fit and how straightforward that change will be.
Leisureshopdirect usually stock a range of pumps and many sing their praises.
