Disaster averted 😅
The laird
Rally Organiser
Just been doing final checks on the van ,heating bled and on (low) taps bled ,just walked past the van and heard light dripping! Strange ,got a torch and water dripping from sill on van,traced to kitchen tap leaking,found cold hose elbow not In correctly so one o my sons and I removed said tap stripped pushed elbow back in elbow retaining pin fully pushed home pipes back on and hose clips fully tightened up
Bled system again all ok now got small heater on drying out cupboard albeit not bad but chudder to think if it had not been fixed
Always the same last minute guff
Thanks no2 son for getting stuck in
Good luck to you both, Gordon.
How far south are you planning to go.. As far as civilisation?
Safe Travels.
If you’re coming down here Gordon, bring some sunshine with you.
We are heading for the Station Inn at Ribblehead this afternoon fir a few beers and a Meal then Skipton Monday and Ripon Tuesday then home Wednesday just get away for a few days.
I had a nightmare this morning when setting off from Penrith with my caravan, heading home to restock before heading to Scotland.
1. Attempted to move the caravan with the corner steadies down, luckily no damage.
2. 15 miles into the journey thought where did I put the motor mover controller. Pulled into the next lay-by and low and behold it was on top of the rear window wiper, god knows how it hadn’t fallen off.
3. 10 minutes after setting off again tyre pressure warning came on for car. Pulled into the next lay-by and all tyres looked ok. Thought sod it I’ll drive to next lay-by and check again, still ok so decided to carry on home.
4. Finally arrived home and daughter hadn’t opened drive gates so had to call her on phone with caravan encroaching onto the main road. Fortunately being a Sunday not much traffic.
Now chilling out watching the football. 😁😁😁
