Disklok
The laird
Rally Organiser
I have a large disklok in new condition of the mercedes but it's to big for hymer small steering wheel anyone want to swap or buy the merc one ?
You need the medium for the Merc
The only difference between the large and medium is they put foam blocks inside the large and call it a medium,
So you could probably contact discklok and buy some foam blocks to make yours a medium.
Failing that I will measure the blocks in mine so that you can make some, they are only stuck in with double sided tape
Thanks for your trouble mate
I have just taken some photos I hope you can see these ok they’re are 6 foam blocks 3 in each side they are of high density foam approximately 1/2” thick by 1 1/2 wide by 2” long glued down then what looks like black duct tape about 5” long over the topB08CD4DA-C83B-467F-9F66-7D75C0B548A7.jpeg3B23344F-F9D0-44E8-9EDF-ECB5BDA87A22.jpegCD94E6B4-F06B-4FA7-8963-AF06552CA3DC.jpeg13F6A61C-FBFF-4AB5-88AF-FC2E70B53C48.jpegC7E4CAF6-65B1-4307-9C3E-0DA258ECC1CF.jpeg0205C790-546D-4584-B68B-CD8219B6BA66.jpegCE0124A9-3070-4020-AF02-B5A0BC1C1A34.jpegFDC32A6A-D2FD-4D56-8B97-4A428F6BAD8D.jpeg
This is a disklok that prevented a landrover defender being stolen ...
Not the attempts at 'peeling' it from the steering wheel ...
This is a disklok that sustained 30 minutes of attack using hand tools available in a well equipped garage (after the key was lost ....
Only eventually succumbed to a grinder including the associated noise and mess ...
There is in my experience (speaking as a owner of several landrovers ...most stolen vehicle next to Transit vans )
The BEST deterrent to thieves both visually AND amount of effort wise .
Glad to hear this as I am the proud user of the Disklock on my M/Home as well as a Wheel Lock & Alarm ......I have been looking at the Nemesis Plus but don't think it's as good as a Bulldog.
I have just taken some photos I hope you can see these ok they’re are 6 foam blocks 3 in each side they are of high density foam approximately 1/2” thick by 1 1/2 wide by 2” long glued down then what looks like black duct tape about 5” long over the topView attachment 67696View attachment 67697View attachment 67698View attachment 67699View attachment 67700View attachment 67701View attachment 67702View attachment 67703
Is that 50 x 35 x 19 ? difficult to make out the thickness.
