Dometic CRX 80
RichardA
Just had a new van converted with CRX 80 fridge. Temperature regulation is entirely up the creek. The freezer rises above (or close to) freezing at all temperature settings. If the freezer is removed there is a constant supply of water forming at the top of the fridge because the temperature up there is bouncing above and below zero.
My last van had a CR 65. It had a similar problem. Much internet searching led me to discover this as a known problem and Dometic had a solution - move the thermostat to a different location. I had this done (Dometic refused to do it gratis!) and it solved the problem.
I now have a new fridge (new model) and same old problem. Has anyone else encountered this and if so have you found a solution?
Richard
