Dometic fridge problem
  • Thread starter Thread starter wylecoyote
  • Start date Start date
wylecoyote
Hi, I have an Auto Sleeper Suffolk with a Dometic RMS 8501 fridge.
Have just been doing some pre season checks and noticed that when on 12v mode the triangle exclamation mark/failure led is flashing along with the battery12v indicator. The actual fridge light comes on when you open the door but it doesn't appear to be cooling.
Anyone had similar problem or know what it might be.
Cheers Phil
Don't know if you have a user manual, but it's problem solving pages are pretty good.
When the two messages you describe are flashing it tells you that you either don't have 12v or the voltage is too low.
The recommended solutions are:
1) Check fuse
2) Flat or low battery
3) Engine not running
4)Heating element defective.
Good luck and I hope this helps!
The good news is that you fixed it yourself, and at no cost. That's got to be a bonus !
