MykCamper
Having just had my driver's airbag warning light extinguished at a total cost of over £1400, due to faulty Body and airbag ECU's repair costs.
There is a common fault with 2006 onwards Fiat Ducato, Citroën, Peugeot models with aircons.
Due to the aircon condensation drain being alongside the airbag ECU which is situated front right of the starter battery, overtime this causes a failure.
The fix is quite easy by removing the ECU and sending it for repair to one of several companies that advertise on ebay. ( There is a step by step guide on Utube, with a Citroën MH.)
Usual takes a few days and cost under £100.
I used a local mobile auto electrician and it cost me but I observed the procedure, so here's hoping this will save members the expense that I encured.
Main dealer cost would be in the region of £500 - £600 for fitting a new unit.
Word of caution,!
Be sure to remove the earth terminal from the battery and isolate before removing the wiring of the ECU to prevent any possibility of setting off the airbag!
I have now placed a thick plastic bag between the ECU and the aircon drain in the hope that it will give some protection.
Hope this will be useful!
Word of caution,!
