nabsim
I am after a bit of advice from you ‘e’ cyclists.
I have a hand cycle that has one 16” wheel at the front and two 20 or 24” wheels at the back and it drives through various guides and pulleys to the rear via a Shimano 7 speed cluster then a short separate chain to the rear.
I am looking at options for adding an electric motor to this and I got rear drive with the intention of adding a 16” electric hub drive to the front if I needed it. Mid/crank drive is not an option as the crank is where the handlebars would be on a bike
So, am I better going fo front wheel electric drive or an electric drive to one of the rear wheels? Only one wheel is driven at the rear so it would be the non-pedal driven wheel.
Lastly, the rules concerning pedal assist and adding a twist grip do not apply if you have a 3 wheeler, only 2 wheelers. The hand crank has a gear selector on the right hand pedal along a with back brake and front brake on left.
I do not want the electric drive to be in use normally only on inclines or if I have trailer on the back with dogs or shopping in it so I presume some sort of on/off switch then either twist grip or thumb throttle on left but I would want it to cut drive when I brake.
Any ideas or on topic (that means you Del) suggestions?
