Slow Giles
Hi,
I have the above inverter installed under my bed, wired up by an electrician into 2 leasure batteries correctly. I then have a remote ET-RC remote screen that allows the invertor to be switched on and monitor the power situation, with both state of battery displayed on the left, load on the right and voltage of the battery system in the middle.
It failed last week, with continuous bleeping from the inverter, and the load monitor on the remote alternating from zero load to maximum load with nothing connected.
Today, i have disconnected and opened up the invertor and checked the 12x30amp green fuses inside,but all are ok.
Any thoughts as to where should check now?
Warranty ran out in April, as it has worked fine for over a year and I installed a wire cage over the invertor to stop it being covered up and over heating...
