Hi carrots it’s all a bit of a mish mash and no skill at electrics on my behalf I just pick things up on here with not having the skill as an electrician I tend to make a problem I don’t have then try buying my way out. I’ve Defanetly overthought things. My set up is two rellion 100 amp lithiam batteries. Two 140 watt solar panels. With a victron Bluetooth solar controller. The efoy is fitted in the background it comes on automatically once the batteries drop to a certain point but with the lithium batteries i haven’t got round to changing the settings because they show 13 volts right to the end. so I turn it on and off manually using Bluetooth. Got all this running through a victron 712 smart monitor. I had a fair bit of advice and help from phil admin. The efoy is an expensive piece of kit but I do like the piece of mind that it gives if I have it ten years with light use then it’s done it’s job.
