Electric going off
Hazel
We went away recently and our electric kept tripping off. We rang choose leisure and their electric expert snd he said the battery was getting over full? Has anyone heard of this. ?
The electric would then come back on about 4 and go off again in the morning every day. We have a solar panel but disconnected that on the advice of electric man.
TJBi
I've just plugged into electricity for the first time in over 5 years, so no great experience with this. Were you on a campsite? Were other people similarly affected? Seems strange that it should be consistently time-related if it's the motorhome.
Molly 3
I had a similar problem ,i put it down to over charging from portable solar panel reaching 15,6 volts , triping out sargent comtrole panel . Changed sollar controller ,hope to test this week.
Hazel
sounds the same please let us know if you solve it.
jagmanx
So Hazel is your solar a plug in portable type ?
And leave the solar disconnected to see what happens.
Given the timings it MAY be too much sun on an overactive panel is the problem !
Hazel
No it isn’t a portable, it’s fixed on the roof. The electric man did say undo it though which we did. We did have electric hook up at that site but had to disconnect that too and the electric came back on about 4. Then we moved to another site with no electric hookup so we connected the solar panels. But exactly the same thing happened. Electric all off after breakfast and would come back on about 4. Someone on the camp site said we must have an old battery but it was fully charged as people tested it.
St3v3
It would be quite unusual, but it sounds like the solar is turning off the feed to the van. Solar controllers do have an output pair of terminals - that are rarely used - that are designed to power lighting. These can be programmed to come on when it gets dark and switch off when light.
Pictures of everything would be useful, especially the solar controller and it's wiring.
What van is it?
nabsim
Has the problem stopped since you disconnected the solar from the batteries? It does sound like solar input is a factor looking at the times on and off
Hazel
no it happened every day. We disconnected the solar at the first campsite and the ehu but it still switched off.
nabsim
Strange it did sound like it could have been related to solar but if disconnected then it can’t be. Have you contacted Sargeant and explained what’s is happening to them, from other posts I have read they see decent support on the phone/email?
Hazel
Yes we can’t fathom it out. No I don’t know sergeant have you a phone number?
I think he will have to take the van in next week.
nabsim
TJBi
When you say that the "electric" kept tripping off, did you mean the 230v mains supply or the motorhome's 12v battery supply?
Trigger
My solar controller has a facility to power extras if required such as out side lights, etc,., this supply has a timer facility on it to select when it operates, could your supply be connected to the wrong terminals on the controller thus working on timed sequence , if you too have this facility??
Hazel
No we are quite certain it’s not that as it’s been fine for 2 years, it just started about 3 weeks ago.
Diver1swife
Hi not really sure if this will help but my moho has a control panel that can switch things on and off, eg power at set times of day. Sounds like yours could be doing this As it is always at the same time.
Hazel
Thanks we don’t think there is a timer on it. It’s possible the battery is old , we are grateful for everybody’s help and please keep ideas coming. We are trying to contact the chap who put the solar in .
