The quiddies
I have just received a snipe 4 sat dish and I am going to fit it myself to my motorhome Over the Christmas break. Has anyone got any advise on the best sealant to use
We did something similar when fitting the solar panel....and then some bloody great screws.Remember that Sikoflex MUST have a thickness. Personally, I used matchsticks under the supports, to ensure that a thickness is created. No thickness, no strength!
Welcome to the forum!
It would help enormously if you poked something just under the edge of the Snipe base, that you will be able to press down on, without squashing all the Sikoflex out from underneath. Once it has set, it should then be possible to pull the (matchsticks) out, and run a thin bead around the base, totally sealing it.Thanks for the tip and thanks for the welcome I was going to cut the nozzle into a V to give the sealer depth
No.I was thinking about not screwing it. But if you was to crash at 70mph is it likely to come flying off?
Good Luck!That sounds great. Let’s hope I have some dry weather over Christmas I have several upgrades to do on the van
If the factory fitting failed or developed a leak Baz, you would at least have some comeback, and they would have to put it right.My solar panel was factory fitted sealed and screwed
