For Sale: Fiamma Privacy Room
I have this Fiamma Privacy Room that I bought to use with my Camper Conversion back in 2018. I found it really useful in that Van (a VW LT) to give extra living space when away at the VW Festivals, Quirky Campers and the occasional camping trip. (Some of you may remember seeing Clarence, my stripey 'Daktari' Campervan at the Druridge Meet back in summer 2018 or 2019 with the Fiamma Room fitted? And someones little doggy decided to 'christen' it with a little wee 🐶 (quickly washed away!))
But I find as a mostly solo camper in a Motorhome, I don't really need the extra room so this is gathering dust in my shed.
However for someone in a smaller camper, multi-person use, or going away for extended periods at a site (maybe Spain in the Winter?), the extra private space this will give will be brilliant! It generally will more than double your living space.
The Fiamma Privacy Room aka Safari Room does need a top awning on the van and comprises the two sides and front panels to make an fully enclosed area. You can also just use one or both sides on their own if you wanted to provide side privacy or as a windbreak, so a very flexible setup.
This is what it looks like with all the sides and fronts on, covers down and closed up on my Campervan ...
Fiamma-PrivacyRoom-2
The top part of the side you see there has a section that rolls up for a clear window; similarly on the other side.
The Kit I got was a 4 Metre one (actually referred to as 410). However the front of the rooms are made up of different panels which zip together. You have a door panel and then window panels, so you can easily make the privacy room smaller by not using a panel or wider by getting an extra panel, so very easy to adapt if you have a longer or shorter awning you are attaching it to.
As well as the Privacy Room itself, I have a full Fiamma curtain set that attaches to the interior pre-fitted rails above the windows to give privacy at night without dropping the outside panels and also look nice as a bonus. (I actually have two different sets, so you can chose which one and even have both for a small extra cost.)
I do also have available a Fiamma Ground carpet to finish off the room, complete with a waterproof backing. I had intended to keep this as can just as well be used on its own next to your camper or motorhome, but if someone wanted the full solution, we can discuss :)
The best way to check the value of the Fiamma Room and accessories is to look on eBay .... A few searches to help are:
(and note - these links are NOT my listings and nothing to do with me. Just links to similar or same kit)
Fiamma 4M Privacy Room - https://www.ebay.co.uk/sch/i.html?_nkw=fiamma+privacy+room+410
This will give an idea of the type of prices these are.
Fiamma Curtains (these are same as mine) - https://www.ebay.co.uk/itm/317113525995
The above are the 'Ocean' ones. I also have same curtains in the 'Oslo' pattern which are more colourful but have not got an image other than this thumbnail
I am asking £350 for the Privacy Room System, which includes the side panels, 3 front panels, Storage Bag, and the two side "Fast Clip" top supports, plus a Fiamma Heavy Duty Tie Down kit and pegs as well as one of the Curtain Sets shown above.
If you want both Curtain Sets, the second one will be £40 (and if you already have a Fiamma Room and want a set of curtains, get in quick and you can grab one of the sets on their own for £40!)
Link to the Breathable Ground Sheet.
Fiamma Awning Carpet Breathable Groundsheet Patio Mat 340cm - This will be an extra cost. I also have the optional storage bag for this Carpet. Handy when packing away in case it is damp and don't want packed against the Privacy Room panels.
The Privacy Room set is too big to post really, but I can take it to Druridge later this week if anyone going is interested or could 'pony express' it for someone else.
If you are interested but think maybe too far away, let me know as might be able to take it to you later this month depending on location.
It looks like a nice sunny day so I might get the privacy room out the bag and put on the Motorhome to take a few pics of it in use :)
Nice sunny day so got the Fiamma Privacy Room out the shed ready to fit ....
Comes in this quality zipped bag.
Fiamma Privacy Room
You get the two "FastClip" sides that clip together and provide a sturdy fixing point for the side walls
Fiamma Privacy Room
And a whole load of pegs and stretchy rubber strap thingies
Fiamma Privacy Room
Looking at these, I doubt if I ever used the pegs as carry loads of them already in the van (like most folk do!)
Now, as this is Scotland and it is Summertime, as soon as I took this out the bag, it started to rain, so all back in the bag and away back to the shed to wait until a bit later on :)
Suns out again :)
Wound out awning ready to fit Fiamma Privacy Room .... Found out I have a Thule Omnistor awning and not a Fiamma :( (For some reason I assumed it was a Fiamma Awning. I suppose as I have a Fiamma Bike Rack and not a Thule one, and thought Autotrail would use a common supplier for bits?)
Not sure if a Fiamma Privacy Room will fit an Omnistor Awning (the parts that sit against the awning van side and rail look different) so will look into that and see if there are adapters/converters.
Always a solution out there ..... https://www.agentfiamma.co.uk/Fiamm...RglihKtNx1ZLtkdCfTO3ISxyCXDevKTtIbkNdsDCExJPJ
"Adapter Kit which allows you mount Fiamma Fast Clip bars to Omnistor awnings. This kit allows you to fit a Fiamma F45 Privacy Room with 2.5m extension and Fast Clip System to Omnistor 5002, 5003 4900 and Tristor 2 awnings."
