EnaC
New to motorhoming not planning on using for a few months, should you put the fridge vents on when not using? Thanks in advance
We get quite a draught from the gaps around the fridge, but I'm not sure that covers would help cos I assume you'd have to take them off to use the fridge on gas? And how can they justify £30 each?
Thank you for posting this info. We haven't got a fridge yet but are gleaning all the info we can ready to get going in the Spring.I do, EnaC, if only to keep wind blown debris and dust at bay.
The manufacturers usually also recommend fitting them when the ambient temperature falls below about 8 degC.
Colin
Do fit fridge vents if you take your van to a car wash. Stops water getting in.
