paulhelenwilko
Considering how to organise the storage in the garage. I have a Spare wheel and electric bike to accomodate, as well as the usual table, chairs, hook up, hose and general motorhome paraphenalia. I would like easy/quick access to the bike.
The garage has a rail each side for tie downs. There is a locker door on the LHS for access to the truma and at the far left access to the Gaslow bottles.
I am reluctant to drill holes in the rear panel and only if neccessary in the woodwork to the left. The previous owner has glued pieces of soft wood to the inside of the doors and to the back wall, they look horrible but would probably look worse if I tried to remove them.
On the rear wall there are 4 vertical aluminum supports for the bed.
Lets start with the wheel, as this is the heaviest item, if it is going in the garage it is best mounted vertical, probably central and forward near the axle. Anyone know of any spare wheel holders that can be used in the Garage ? The other possibility is to mount underneath, the chasis is a Ducato Maxi anyone got experience of mounting the wheeel underneath ?
The bike takes the full height of the garage but is quiet narrow with folding pedals and handle bars that twist. I was thinking of modifying an old cycle roof rack to hold the bike in place and position it towards the back wall.
Then I'm thinking of creating some kind of racking to take table chairs etc and all the other paraphanailia. Anyone got any suggestions for lightweight racking ? Fiamma do some but it seems expensive.
Any ideas suggestions welcome.
