No. I have the 780 Camper SatNav x 2, and have never been able to download the map updates. My solution is to use 3 SD Cards (£7.99 each from Argos). Back up the device then insert a formatted SD Card and download the new map and associated software. Then go to the Backup file and reinstate the 'Favourites' campsites and Aires. Repeat for 2nd Garmin (Avtex) 780, leaving the SD Card in each device. Keep the 3rd SD Card, formatted, ready to start the next update ...I am unable to install the latest map update, Garmin suggest I install a SD card. Before I buy has any one deleted all the foreign voices or maps they don't use to fee up memory space?
Wow, thanks Steve. Wasn't expecting it to be that awkwardNo. I have the 780 Camper SatNav x 2, and have never been able to download the map updates. My solution is to use 3 SD Cards (£7.99 each from Argos). Back up the device then insert a formatted SD Card and download the new map and associated software. Then go to the Backup file and reinstate the 'Favourites' campsites and Aires. Repeat for 2nd Garmin (Avtex) 780, leaving the SD Card in each device. Keep the 3rd SD Card, formatted, ready to start the next update ...
Bit of a faff, but it works first time, and is quite quick; far preferable to having the update crash after 3-5 hours using the (partially filled) SD Card, because the supposed temporary transfer of retained files to the laptop to create sufficient update space doesn't work
It does work, Mike, but it is a process I dread. Did the last update on early January, but couldn't find the spare SD Card. Bought a replacement (that's how I knew the price), got home, and then remembered that the SD Card was in the Passports Wallet ...Wow, thanks Steve. Wasn't expecting it to be that awkward![]()
I would guess that as you were using Windows, that is what they checked.The story continues...
My son offered to look at the Sat Nav after I told him that Garmin confirmed a fault and said if the reset didn't work all they could do was a part exchange against a new one.
He connected it to his Mac computer and all worked ok!!!
Why Garmin confirmed the fault and why wouldn't a Windows 11 laptop install I don't know.
Will leave the next update for as long as possible![]()
