Gaslow seems to be frozen
  • Thread starter Deleted member 3942
  • Start date
Deleted member 3942
the cooker stopped working tonight never ever had that happen in all the time I have had gaslow.
Was making a brew getting ready for bead nice coco no gas haven't run out as we have filed up today.
fridge not working or gas heater so I have connected a bit of hover hose and rooted it in to the gas locker.
ihave taken the filer pont out of the door and put it trough there for now se what happens with a bit of warm air on the regulator from the diesel blown air
bill
COULD (?) well be the regulator has failed.
Happened to use very similar symptoms
Its not cold enough for gaslow to freeze. Autogas is, mostly, propane in the UK - and that will be fine.
(In cold constant <4' temps, its possible that gaslow only gasses the propane, so at 50/50 mix you only use 50%, then reful, then you can only use 50% of the 50, so 25% etc, and eventually have a tank of butane. But we're talking very very cold over a duration. And depends on the autogsas mix.
If you only filled up today, assume 50% of that was propane, its not likely its frozen.
Blah blah
Most likely blockage or regulator, (unless you are in the mountains and its been <4' in the gas locker for days), or duff gas (as filled today). (Maybe more moisture than normal in he gas and *that* has frozen rathe the gas not gassing).
Assume you turned the valve off for filling. You did turn it back on.....? :)
Do you have a pressure gauge pre/post regulator?
