Carrerasax
Can you get some one to laser print one for youHi
So is this door lock box serviceable
My external door handle doesn’t close when the handle mechanism jumps off the piece of plastic that it rests on, due to a worn edge.
Anyone know who makes these as whole thing is £225 on eBay
View attachment 75836View attachment 75837
I thought that butCan you get some one to laser print one for you
You need the program for that part to print itI thought that but
Don’t for one moment understand all that stuff
My grandson on IOW has a 3D printer but how does it copy something![]()
No, I think it’s the arm of the handle on the external side that slips off the flat section, retained by the silver screwIs it the linkage that jumps out of its hole? Not quite sure which part you mean?
Ah ok, not such an easy fix then.No, I think it’s the arm of the handle on the external side that slips off the flat section, retained by the silver screw![]()
What did you mean.If you think the worn edge is the problem, can you not rebuild it with a 2 part epoxy?
Yes, that is what I mean.What did you mean.
Building up the worn edge and shaping by filing it![]()
