Habitation check - am I expecting too much?
  • Thread starter Thread starter Deleted member 333
  • Start date Start date
Yes I now remember Plusgas.
Might be needed for the nuts on the mechanism which holds the spare wheel under the vehicle.
Not now...... I need a safe way of raising the vehicle so I can crawl underneath.
I use the leveling ramps. Milenco quattros get quite a bit of lift to get under for maintenance and super safe👍
I really rate ACF50 in place of wd40
Thanks I have used the "yellow blocks" but I get increasingly wary in my old age
I work for a motorhome dealership and we will inform the customer that there is a problem and will fix it during the service but if it takes longer then will inform the customer, we also do RCD testing which some companies don't always check
