. I would much prefer a gas fire but manufacturer don't fit it any more, they only seem to fit leccy guseling ,unreliable electronics, need servicing ???????? I can see that hot air could be beneficial in a large van with fixed bedI've only got one option... the Truma gas fire. Absolutely no complaints though because it makes the van toasty in no time and as it's not a blown air system, it doesn't drain the batteries at all.
Those old Carver caravan fires used to throw the heat out from what I remember but isn’t it something to do with moisture in the air why they changed to blown air or have I got it wrong? (Probably got it wrong ). I would much prefer a gas fire but manufacturer don't fit it any more, they only seem to fit leccy guseling ,unreliable electronics, need servicing ???????? I can see that hot air could be beneficial in a large van with fixed bed
Me too Colin though I did put the blown air heating on once in the outer Hebrides when the beast from the east hit other than that it’s s thick jumper too.A thick jumper does it for me.
It also does it for the environment.
Soft Southerner? Think again.
Colin![]()
Not very careful with their offering as it says 4kw but then in the list of parts supplied it says a 5kw heater. £299 is way to cheap for a fitted diesel heater.Blown air gas powered but a leccy convection heater if on EHU.
Spotted this ...https://www.ebay.co.uk/itm/283116585209
Cheers
H
I found the lecy in the truma is not as hot as gasWe usually use the Truma on Gas and use a fan heater if on electric, which is pretty rare.
However our new van has an electric option on the Truma, but we have not as yet tested it, apart from knowing it works, so I will still take a fan heater!
